Total posts in this thread: 1
Previous Thread This topic has been viewed 3608 times and has 0 replies Next Thread
gcalavaro
Italy
Toggle to show or hide wall coordinates
When I need to review a draw I need to show each wall Modification window, to see the coordinates the wall start and end using the "Modify" function, take a note of the coordinates at both ends, and close that window. Then repeat for another wall.
Is there a function to toggle SHOW/NO SHOW of wall coordinates?
The default would be the actual situation, that is NO SHOW.
When you toggle SHOW=YES, it would be nice to see, eventually in another color like blue, close to each end of wall, the walls coordinates.
See example below.
I need to do this when for example I moved a bit the walls for one floor and I need to check if the move was done also for the other floors.
Thanks for any suggestion.
Peppe
[Nov 24, 2018, 6:50:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
