Total posts in this thread: 6
Previous Thread This topic has been viewed 5166 times and has 5 replies Next Thread
enkonyito
Ambient lighting of a room
It is possible to use unviewable light panels to have the ambient lighting of a room.
The trick is to place them at the level of the ceiling, on all its surface, making sure that their edges enter the walls in order to avoid the effect of shading.
The first panel facing downwards (X axis rotation: 270°) and the second one facing upward (X axis rotation: 90°).
Illustration with the SweetHome3DExample14-HaussmannStyleApartment project of the gallery.
Bathroom without lighting
Bathroom with ambient lighting
Bedroom #1 without lighting
Bedroom #1 with ambient lighting 1 (face-down panel)
Bedroom #1 with ambient lighting 2 (face-up panel)
Bedroom #1 with ambient lighting 1 & 2
Depending on the shape of the room, you can use several panels to cover it.
Enko
EnkoNyito
[Mar 7, 2019, 8:33:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Ambient lighting of a room
Hi Enko
"Bedroom #1 with ambient lighting 1 & 2" does look like it is a room with no artificial lighting, but, surely all you have done is replace the ceiling with a light source rather them illuminate it.
In a room with lighting this would look unnatural as a central source's light would decrease further from the source, would a circular (disc) shape light source be feasible. Just a thought.
[Mar 10, 2019, 2:32:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hi again, only me.
Hope you don't mind me posting an image to illustrate what i was trying to explain, i apologise if you do.
I achieved this
with this.
But 64 sources seems overkill if a single source could be used, resized and elevated similar to my light wheel, i know, great name, took me hours to think of it. biggrin
Still seems a shame to have too try so hard to illuminate a white ceiling when, as you can see, the grayness does not affect the cornice, but that's another story.
Thanks in advance for any assistance you have time to give.
[Mar 10, 2019, 6:53:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hi Mike,
I did a recent test with your file (the standard ceiling has been replaced by a white textured box) => same result ! sad
[Mar 11, 2019, 6:05:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Hi Mike,
According to the Sunflow documentation, only the PointLight and TriangleMeshLight types are attenuated light sources.
By ambient lighting, it is necessary to understand the minimum lighting so that a room is visible without artificial lights.
Take the example of your closed room with a rendering in quality 4 (default values).
I add 2 light panels of the same thickness as the cornices and the dimensions of these grouped.
Panels halfway up the ceiling (example 1)
Panels up to cornices (example 2)
Enko
EnkoNyito
[Mar 12, 2019, 2:58:13 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
enkonyito
Example with automatic ambient lighting panels.
EnkoNyito
[Apr 26, 2019, 12:13:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
