Previous Thread This topic has been viewed 6322 times and has 2 replies Next Thread
bbxrider
United States
reconcile wall length with inside room dimensions
I'm a fairly newbie sweet home user. not sure how to reconcile inside wall dimensions when I have created my home plan wall by wall, please see below, the inside wall dimension is 14' 3" the length I have given to the wall but when I measure out the same distance, the ruler is longer than the walls inside dimension.
it would seem I have to give the wall property a greater length than the actual inside dimension. the walls width is 4.5" for a 2x4 with sheet rock on either side. however the exterior walls will be 5.25" for 2x4 with 3/4" sheathing and 1" of stucco
is there some way to tell sweet home a wall length is the finished inside dimension?
the preview is not showing the google pic link using the image tags, so I am providing the raw link here so it can be seen just in case
https://photos.google.com/photo/AF1QipNxbwZHzkhrbvboJR03OnSvD6JCzi2BgZa0VuKI
[May 13, 2019, 1:02:36 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: reconcile wall length with inside room dimensions
You should view this video which explains how to draw rooms from their inner dimensions.
Hope this will help...
[May 13, 2019, 9:12:24 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
bbxrider
United States
thanks for the reply, that is a great feature, to get my existing house all drawn out probably still have draw some walls
[May 18, 2019, 10:42:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
