I can´t run this program. I try everything maybe. First start screen of sweet home and fall. And then it´s create file - hs_err_pid1008.* I think, that problem will be in Java script. I´m already installed version 1.6.0_03
I´m install Sweet Home on ohter computers - and any problem. Only on my computer.
Can You help me?
Thanks.
radekfric
all text in this file:
# # An unexpected error has been detected by Java Runtime Environment: # # EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x09efc964, pid=1008, tid=3084 # # Java VM: Java HotSpot(TM) Client VM (1.6.0_03-b05 mixed mode, sharing) # Problematic frame: # C [extension15135.dll+0x5c964] # # If you would like to submit a bug report, please visit: # http://java.sun.com/webapps/bugreport/crash.jsp #
--------------- T H R E A D ---------------
Current thread (0x053c7800): JavaThread "J3D-Renderer-1" [_thread_in_native, id=3084]
Other Threads: 0x02b0cc00 VMThread [id=2140] 0x02b55c00 WatcherThread [id=1196]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap def new generation total 960K, used 656K [0x1a9b0000, 0x1aab0000, 0x1b870000) eden space 896K, 71% used [0x1a9b0000, 0x1aa4f898, 0x1aa90000) from space 64K, 28% used [0x1aaa0000, 0x1aaa4a18, 0x1aab0000) to space 64K, 0% used [0x1aa90000, 0x1aa90000, 0x1aaa0000) tenured generation total 7184K, used 5754K [0x1b870000, 0x1bf74000, 0x269b0000) the space 7184K, 80% used [0x1b870000, 0x1be0e970, 0x1be0ea00, 0x1bf74000) compacting perm gen total 12288K, used 5229K [0x269b0000, 0x275b0000, 0x2a9b0000) the space 12288K, 42% used [0x269b0000, 0x26ecb798, 0x26ecb800, 0x275b0000) ro space 8192K, 62% used [0x2a9b0000, 0x2aeb14a8, 0x2aeb1600, 0x2b1b0000) rw space 12288K, 52% used [0x2b1b0000, 0x2b7f7278, 0x2b7f7400, 0x2bdb0000)
If anyone is interested, after searching again through these posts, I realized I had overlooked a comment by the developer that mentioned updating the video card driver. Unfortunately, my old Dell laptop has its own issues with video card drivers in Linux, and if anyone knows how I could get above the 810 driver and (hopefully) be able to use Sweet Home 3D again, that would be great.
In the meantime, I was wondering what a recommended amount of memory to be allocated to the card would be? I set it at 300k, should this be enough to run the application?
Re: Fatal Error... update from original poste
Sorry if I'm not able to help you more than that, but I don't master video card drivers configurations. Anyway allocating 300k to the video card is probably not enough. If you know Java, maybe you could checkout the project and use Java 3D 1.3.1 instead of Java 3D 1.5.1 library.
Re: can´t run sh3D
Sorry for this problem. It's probably a problem with your video card driver as described in bug #1811441 https://sourceforge.net/tracker/index.php?fun...id=152568&atid=784665 Once Java 3D team will have succeeded to fix this problem, Sweet Home 3D will be able to warn you about this problem in a clean way, at least.
