Total posts in this thread: 2
Previous Thread This topic has been viewed 6229 times and has 1 reply Next Thread
tapani
Finland
Separate texture scaling for each dimension
Would be nice to have the texture scaling option for each dimension (x, y z) separately. Also there should be a lock for the texture aspect ratio.
When I assign a texture to an object and then change the texture, it does not change in all existing objects. So instead of copying the texture to objects, a reference should be made.
[Oct 31, 2019, 10:27:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Separate texture scaling for each dimension
Hum, I should you should try to understand how texture coordinates work. Texture scaling can be made on 3 dimensions!
[Oct 31, 2019, 11:08:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
