Previous Thread This topic has been viewed 8713 times and has 13 replies Next Thread
Per_Jonsson
Different floor textures in different rooms?
Thanks for a _great_ program!
Is it possible to have different floor colors/textures in different rooms?
/ Per
[Sep 8, 2008, 4:06:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pencilart
Re: Different floor textures in different roo
That would be a great addition. I would like that too.
[Sep 8, 2008, 5:38:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
It's not possible at this time.
I'm working on it. Next version should allow the user to change the color/texture of each room individually, and to import additional textures.
[Sep 8, 2008, 6:56:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pencilart
I thought of a bit of a work around:
Use the cube that you provided (the box in the Miscellaneous category) and just flatten it. Then apply a different color for each room that you've put it in. However, it would be a problem if the room is not square or has a "bay" area (sticks out with the walls at an angle other than 90º.)
[Sep 8, 2008, 7:09:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Rooms with their own texture or color were added in version 1.5
[Dec 10, 2008, 12:18:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mnemix
Re: Different floor textures in different rooms?
I'm using the 1.5 version but I can't apply different textures or colors to the room's floors. Why? How can I do it? Thanks for this great software.
[Dec 13, 2008, 8:28:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Create a room with the "Plan > Create room" for each floor you want to change, and then modify the room.
[Dec 13, 2008, 9:02:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mnemix
But, when I try to modify the room, I don't obtain any menu, neither double-clicking on it, nor right button of the mousse. How can I modify the floor of each room? Any screenshot to show it to me? Thanks and congratulations for the software.
[Dec 16, 2008, 1:21:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
pencilart
I hope this helps!
http://i64.photobucket.com/albums/h186/gymnart/SH3D_modifyroom_tut.jpg
[Dec 16, 2008, 4:57:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mnemix
Ok, I've yet tried it, but when I right click at 2D grid the sub menu pop up, but when I select "Modify Room" doesn't happens. When I right click at 3D View I can modify the main floor (grasp, sky...), but not the room floor. What's going wrong? I'm very desperate.
Thanks
[Dec 16, 2008, 7:58:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
