Previous Thread This topic has been viewed 5032 times and has 2 replies Next Thread
Martin_Peris_Martorell
Head angle
Hello everybody,
Sorry if this is not the right place to post this question.
I need to 3D model a small and easy indoor environment, so I find Sweet Home 3D just perfect for the task.
There is just one small detail that makes it not suitable for my task. In "Virtual visit" mode the maximum allowed "Head Angle" value is 75 degrees. And I would like to set that maximum value to 90 degrees.
I guess it should be easy to modify the source code to achieve that, so I downloaded the source code but I don't know where to start.
Any hint?
Thank you very much in advance.
Martin
[Oct 3, 2008, 11:37:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Head angle
You must have a good neck ! ;-)
Search "75" in com.eteks.sweethome3d.swing.PlanController class (look at
http://sweethome3d.cvs.sourceforge.net/viewvc...roller.java?revision=1.75 ), and you'll guess how to change it.
[Oct 3, 2008, 2:58:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Head angle
Thank you very much!
That solved my request ^^
[Oct 13, 2008, 12:26:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
