Total posts in this thread: 2
Previous Thread This topic has been viewed 4764 times and has 1 reply Next Thread
Neonkiller
India
sad Cant Open Home Error
Everything was working fine till yesterday, suddenly the file is showing "Cant Open Home" Error when I am launching the file, Please Help
https://drive.google.com/file/d/1ePqnEL34-Qrz...whpJH_FH/view?usp=sharing
[Feb 5, 2020, 6:36:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Cant Open Home Error
The file you shared contains only zeros i.e. no actual data. This error happens rarely and nobody found a way to reproduce it, so I can't fix it. Nevertheless, I had an idea to circumvent this issue in version 6.0 and wonder if you use this version or a more recent version. Is it the case? Any other hint which could help me understand how it happened?
Anyway maybe you can use this tip to recover recently opened files:
Look in the sub folders of C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D\work (where user is your login name) if you can find some files starting by open and suffixed by .sweethome3d. If there's any, it will contain the a copy of the document you recently opened. Copy the most recent file(s), change its extension to .sh3d and try to open it with Sweet Home 3D.
[Feb 5, 2020, 11:56:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
