Sweet Home 3D Blog
Sweet Home 3D 3.3
Sweet Home 3D 3.3 was released on July 26, 2011 with minor improvements and regression bug fixes described in version history.
Hope this maintenance version will be stable as a rock!
I also checked Sweet Home 3D works correctly under Mac OS X 10.7 (Lion) where Java isn't included by default anymore. The installer version, Java Web Start version and online version all worked nicely once Java module was downloaded/installed upon system request. By the way, it would be nice if Java download/installation could work as nicely under Windows and Linux!
At this time, I just noticed a few minor issues in the online version under Mac OS X Lion which comes only with Java Plugin2. As dragging furniture from the catalog to the plan doesn't work anymore, I added a button in the tool bar that will let you add the selected furniture to the plan (the same button as in the other versions).
I hope Apple will be able to fix this bug quickly because it's definitively not the most handy way to add furniture in the plan!
Tags : ,
Avatar: Ariel
Re: Sweet Home 3D 3.3
 Hello.
It is a great program! It is functional and simple to use. Nice 3D preview, I can see how I changed my room :) and the best thing... it is free. Highly recommended !!! Very very very good if you want to change your rooms.
PS: one thing that Author could add is a kind of "sticky walls". It means if you are adding a wall and it is a few cm to the another one, it could stick together.
© Copyright 2006-2021 eTeks - All rights reserved
