Re: Export plan image
Did you use Plan>Export to SVG format? I haven't seen a limit there. I just exported a huge plan to SVG. Result: a 74MB SVG file with 30591x30590 pixels. (The plan I used is about 306x306 meters.) Inkscape had no problem opening it and that's where I got the pixel information from.
Which version of Sweet Home 3D did you use and on what system?
[Edit 1 times,
last edit by Keet at Nov 19, 2023, 7:48:17 PM]
Hello Keet,
I'm using the latest version 7.2 and the goal is to have a png or jpeg file output.
My question was about Tool > Export plan image.
I just tried it with Plan > Export svg option, in fact the quality is perfect. With a converter behind, I was able to obtain a jpeg.
For a future version, it could be interesting to remove the limitation of Tool > Export plan image option to directly have a high resolution image file.
