Total posts in this thread: 15
Posts: 15   Pages: 2   [ 1 2 | Next Page ]
Previous Thread This topic has been viewed 13500 times and has 14 replies Next Thread
choppyleo
Cameroon
Problem of executing the source code on eclipse
I followed the instructions on Readme but when I executed the program I obtain the error messages as shown below. Can someone advice me on what to do at this stage
Exception in thread "main" java.io.FileNotFoundException : -Djava.ext.dirs=C:\Windows\System32\lib\windows\i386;lib (La syntaxe du nom de fichier, de répertoire ou de volume est incorrecte)
at java.io.FileInputStream.open (Native Method )
at java.io.FileInputStream.<init>(Unknown Source)
at org.freehep.util.io.ASCII85InputStream.main
(ASCII85InputStream.java:147 )
[Aug 11, 2014, 1:01:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Problem of executing the source code on eclipse
You mixed up "Program arguments" and "VM arguments" in eclipse run configuration.
[Aug 11, 2014, 1:11:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
choppyleo
Cameroon
Thanks, I have corrected that and now seeing this:
Usage: ASCII85InputStream filename
[Aug 11, 2014, 1:24:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sree.arun.kr
INDIA
Can you explain how to build runnable jar (sweethome3d.jar=2.55MB)or an exicutable jar(sweethome3D.jar=22MB)or sunflow.jar-0.07.3i?.
[* Don't know about programming not only java but downloaded apache-tomcat7.0.zip +ant1.94.zip +JDK1.7 but next step ...? ]
Intreasted to learn and tweak. angel
Thanks in advance. applause
[Aug 11, 2014, 1:41:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
choppyleo
Cameroon
I think I know how to creat that but I don't know how your reply is helpful to my question. Thanks
[Aug 11, 2014, 2:06:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sree.arun.kr
INDIA
Importing source and editing java code is success then now looking for a 10-20 step tutorial from a developer/programmer.
All kinds of tips are welcome. applause
[Aug 11, 2014, 2:17:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
choppyleo
Cameroon
Please sree.arun.kr I don't get clearly what you are driving at cos I asked a question and maybe I don't understand you but I still don't see how your reply helpful to my question on trying to execute sh3d on eclipse. Thanks
[Aug 11, 2014, 2:25:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sree.arun.kr
INDIA
Question is simple
When I get the SH3D sourcecode then how to build a jar application using Eclipse.?
If you are successfull to create a sweethome3d.jar then share the methods you used.
Thats it. applause
[Aug 11, 2014, 2:35:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
choppyleo
Cameroon
If you have already imported the source code on eclipse(but if not then follow the step of the Readme file).
After doing so then follow the steps on then site: http://www.wikihow.com/Create-an-Executable-File-from-Eclipse
Good Luck
[Aug 11, 2014, 2:57:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sree.arun.kr
INDIA
Sourcecode importing and editing is done but exporting an exicutable jar is not enough successfull. Looks it need more tutorial about scripting. Anyway thanks for your help.(Your link is I already covered but thank you once again for sharing). Have a nice scriptingpeace
[Aug 11, 2014, 3:29:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
