Czech Republic
Install pugin in Linux version
Hello, I downloaded SweetHome3D Linux version, where it runs without installation (just unpack and launch SweetHome3D script) The application it self runs without problem.
As next step I wanted to add some the Plugin. Here http://www.sweethome3d.com/pluginDeveloperGuide.jsp I have read, that plugins should be added here: .eteks/sweethome3d/plugins of your user folder. In my case the subfolder plugins was not there, so I created it
Re: Install pugin in Linux version
I guess you are trying to install the plug-in #8. You should copy TheRestOfTheFurnitureInTheRoomplugin.jar file in .eteks/sweethome3d/plugins folder rather than the RAR file which contains the source code of the plug-in.
Maybe my message wasn't clear enough: Do not copy RemainderPlugin.java it won't work. Copy TheRestOfTheFurnitureInTheRoomplugin.jar in /home/zoja/.eteks/sweethome3d/plugins/
Czech Republic
Thank You... TheRestOfTheFurnitureInTheRoomplugin.jar works. But the plugin about which I spoke I thought will be able count cubic meters of walls. Exist some such pluging to get m³ of wall?
