Sweet Home 3D Blog
Sunlight simulation
This tip shows how to make a video in which you can see where the sunlight goes by in a room during a day.
Design your room and place lights
Imagine you designed with Sweet Home 3D the following classroom (available in the file Classroom.sh3d - designed by eTeks and distributed under CC-BY license):
Classroom
And you wonder how the sunlight will goes by in the room seen from a point of view placed at the rear:
Classroom from rear
Of course, if you want to see where the light goes during the day, the room should have some windows placed on a wall that is not oriented to the North. You should also add your own lights in the room in order to obtain a good result, even at a daytime, because sunlight doesn't bounce on objects or wall in Sweet Home 3D.
Then check the result at a moment of the day with the photo creation tool at one of the two best quality levels.
Create a video
Choose the point of view from which you are going to see the light passing by.
Then select the 3D view > Create video menu item, unselecting the Add ceiling lights checkbox to use only the lights you added if necessary. Choose the time at which you want to start your video. Click on the red button to select the beginning of the video. Then choose a later time at which you want to end the video and click on the red button again to fix the end time of the video. To create a video with the sun, you must choose one the two best quality levels, but since the video takes time to compute, you can make first tests by selecting the third quality level instead of the best one.
Once ready, click on the Create button, wait the end of the video computation, and click on the Save button.
Here is what it gives at the 3rd quality level betweem 9:00 and 19:00:
Once you've obtained a result that pleases you, you can choose the highest quality level and a larger resolution. Keep in mind that changing the date will probably give a different result, according to your geographic location. If needed, you may adjust your latitude and longitude with the dialog box shown by the Plan > Modify compass menu item.
For example, here's a video at the best quality level rendered in Oslo (Norway) computed at a resolution of 1280x720 pixels:
Thanks to Sophie for her help in the writing of this tip.
Re: Sunlight simulation
Fantastic!!!
Great, but where/how did you define that the video should take 4 seconds?
Avatar: Emmanuel Puybaret
The frame rate is fixed and equal 250 frames per day for this kind of simulation. As this video starts ay 9:00 and ends at 19:00, i.e. 10 hours and 10 / 24 * 250 = 104 frames. At 25 frames / second, it makes a video of 4 seconds.
Avatar: Joan Perez
I'm using the latest version (in spanish) but It is not shown "date" or "time" in "create photo" or "create video" windows.
 These settings are available only at the two highest quality levels.
Avatar: D
Wonderful feature. I just struggled to realise that 1. Make a red dot point at say 6am. then 2. Change the time, and make another red dot point at say 6pm. So there are two points are different times. Great. It would just be nice to see the clock time in the video ticking through.
Hi! Seems to be a great tool! But can we use it with the online version of the software, or only the downloaded one? Thank you!
The photo and video creation tools are not available in the Online version for the moment. Maybe one day...
© Copyright 2006-2023 eTeks - All rights reserved
