Sweet Home 3D Blog
Sweet Home 3D 7.3
Sweet Home 3D 7.3 was released on April 4, 2024 to fix some bugs described in version history.
Some wrong computations on mirrored objects and furniture groups were fixed, and plug-ins adding items to common Edit, Furniture, Plan, 3D view menus will fill existing menus when not translated, instead of creating useless menus in other languages.
It fixes also the display of file dialog boxes under Windows in some circumstances which prevented to save files under the name of your choice.
As a bonus, a new example was added to the gallery showing a mas provençal (≃ cottage in the South of France) with a swimming pool at a lower level. The slope between the two levels was designed with the Terrain generator plug-in. Hope it will warm you a little during this cold and rainy spring.
Mas provençal by Véronique Puybaret
Tags :
Avatar: Joop Klinkhamer
Re: Sweet Home 3D 7.3
I ma trying to uninstall it, because it totally messes up the 3d rendering!! But the 7.1. version is hard to install because i cannot find an exe version.
Avatar: Emmanuel Puybaret
You'll find the installers for all versions at https://sourceforge.net/projects/sweethome3d/files/SweetHome3D/. But I don't think that reinstalling an older version will change anything. If you installed the 32 bit version (see About dialog box), you should rather try the 64 bit version by running the installer again and select the 64 bit architecture when prompted (or the opposite if you installed the 64 bit version).
Avatar: Rob
Here in New Zealand it is a cool sunny Autumn. But thanks for the update anyway!
Avatar: Anonymous
Dear users of sweet home 3D, I have a space of 4mx3m bedroom, and I would like to gain the optimal maximum space possible for the room. I would require some help from you to help me in organizing my space. I have a sh3d simulation files. For those who are interested, please reach me out via my Email and I will send you the sh3d files, so that you can edit and propose your idea. Best regards, User
Please use the forum for such requests.
Avatar: Pablo
I hope this version become available soon on Flathub, for the Linux world!!
I personally propose only Linux scripts at SourceForge.net.
