Total posts in this thread: 7
Previous Thread This topic has been viewed 5143 times and has 6 replies Next Thread
kfir
sweet hoe 3d will exit now because a fatal error ....
hi
i update to the last version and try to open previous files and getting this message :
"sweet home 3d will exit now ecause a fatal error in the 3d rendering system of your computer. please update the DirectX/OpengL drivers of your computer graphics card"
i didnt make any changes before i update.
does anyone have an answer or solution for this problem?
[Apr 1, 2022, 7:37:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Re: sweet hoe 3d will exit now because a fatal error ....
Which operating system are you running?
[Apr 1, 2022, 7:46:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kfir
windows 7.
the version before the last was ok so i downgrade to it and still have the same problem
[Apr 1, 2022, 7:48:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Does the error happen only when opening a file or even starting the program alone?
[Apr 2, 2022, 12:28:47 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Did you try the suggestions in the FAQ?
[Apr 2, 2022, 12:58:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kfir
one more thing:
on the new version,when i build somthing and save the file and try to open it after few minute ther no problam and everything is ok.
only when i try to open an old file it open and showing me the message.
[Apr 3, 2022, 8:21:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
kfir
Thank you Emmanuel Puybaret it works
i uninstalled and install again (32bit) and it works.
again, thank you
[Apr 4, 2022, 6:32:00 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
