Re: How to save plan/layout as image (PNG)
You can select all the objects in plan then choose Edit > Copy menu item to copy them in the clipboard, then paste this image in any drawing software or in a word processing software (copy / paste may miserably not work under Linux). You can also choose the Plan > Export to SVF format menu item, and convert the SVG file you'll get in a PNG with Inkscape or other software that supports SVG file format.
