Total posts in this thread: 2
Previous Thread This topic has been viewed 3080 times and has 1 reply Next Thread
msingh
confused Setting the origin of objects
I have noticed that the center of each rectangular object defines its (0,0) point. How do I move the origin to the top left for objects? I am putting together a layout that requires that "top" edges of each object be precisely aligned. The objects are not the same size. To avoid having to do possibly needless calculations of the origin for each object, I want to move the origin to the "top" "left". Better still, set that as the default origin for all new objects.
How do I do it?
[Aug 25, 2013, 8:54:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Pixelwizard
Re: Setting the origin of objects
you can arrange objects by using the third menu rom the main menu.
just activate all of them you need and then select from the menu the option of alignment.
WIN10 Pro 64bit * 16 GB RAM * AMD FX 6100 * Geforce GTX 660
[Aug 25, 2013, 11:16:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
