Total posts in this thread: 197
Posts: 197   Pages: 20   [ Previous Page | 11 12 13 14 15 16 17 18 19 20 | Next Page ]
Previous Thread This topic has been viewed 1153253 times and has 196 replies Next Thread
Re: Sweet Home 3D 6.0
What makes you think it's because of the version 6.0? Under what system do you use Sweet Home 3D? What error do you get?
[Nov 4, 2018, 11:00:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Jerintho
Hongarije
I was first using version 5.7 without any problems (Windows 10 system). After updating to version 6.0, the program crashes as I try to save my drawing. After going back to 5.7 everything works great again...
I will try to uninstall first and re-install 6.0. I hope it will be fixed then.
By the way, love your stuff!!
[Nov 11, 2018, 9:25:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Jerintho
Hongarije
Made a fresh install, everything works great now!
[Nov 11, 2018, 9:41:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
WARNING For those who usually modify the look and feel.
Same features of the v.6.0 may not work because of this.
E.G.
I use
-Dswing.defaultlaf=javax.swing.plaf.nimbus.NimbusLookAndFeel
With this option the math formula in number box are not processed.
Without this (original file) it work perfect.
[Nov 21, 2018, 8:26:39 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Raevlav
Rus
sorry guys if this is not the proper topic or these problems have been already discussed.
After upgrading to v.6 'Catalog icons' option of 'Furniture icons in plan' in 'Preferences' is not available. So all the models at plan now are shown as top view icons.
Also two lowest (fastest) qualities in 'Create photo' are not available too (the slider just cannot be moved to the corresponding positions).
[Nov 21, 2018, 6:38:02 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Kunda
@dorin can you provide a screenshot of what the end result of modifying the look-and-feel of SH3D looks like ?
[Nov 28, 2018, 5:43:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Is not a big deal only look a little bit better
The standard:
The nimbus:
Remember the Warning: with this look-and-feel setting some function DON'T work. I've discover at this moment only the math formula issue but could be more other.
[Nov 29, 2018, 8:23:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
maureenowaters
So beautiful, just love it.
[Oct 13, 2019, 7:48:58 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
3DMR
Nederland
Hi Puybaret, I managed to open and close a door with Blender.
In SweetHome I can now see the option (Modify opening) but the textures of the door and hinges are transparent after exporting them (OBJ) from Blender.
(The door frame is not transparent).
What should I do to make the textures solid ?
[Feb 3, 2023, 11:07:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
3DMR
Nederland
Hi Puybaret, Found it and I'm a little embarrassed, I forgot to look at the "normals" in Blender, they weren't all facing out. Sloppy of me but maybe someone else can benefit from the "solution".
[Feb 3, 2023, 2:25:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
